[Qgis-user] Bug Qgis 3.22.1
Nicolas Cadieux njacadieux.gitlab at gmail.com
Mon Dec 6 06:11:55 PST 2021
While I am still on 3.20, I suggest you try again. Make sure the layer is selected and in editing mode, that you are adding the correct geometry type for the layer.  Check the CRS as it’s possible that this could be a simple reprojection issue.  Explain the exact steps you used as the image does not give us any information. Indicate what OS you have.
If you continue having problem, I suggest you create a new user profile.  That will remove the plugins and restores GUI defaults  It fixes many issues.
If this is a true bug, then I suggest you start with the above steps and then write a formal bug report.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 6 déc. 2021 à 06:17, info at otuff.com a écrit :
> Hello,
> After updating to Qgis 3.22.1 (on win10 fr), I think I encountered a bug!
> I drew a polygon on a new layer, but after saving layer, the polygon is not on any layer !!! as you can see on the jpeg below:
> <bug_Qgis3.22.1.jpg>
> What to do to recover a functional .Qgis project?
> Thank you
> Olivier
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211206/4e6f4906/attachment.html>
