[Qgis-user] basic contouring and kriging
Nicolas Cadieux njacadieux.gitlab at gmail.com
Mon Dec 6 13:51:28 PST 2021
Open the Processing toolbox panel, search for 'Krigging'.  You will see
multiple SAGA modules. If you search for "interpolation", you will find
IDW AND TIN under Q modules and other methods under the SAGA module. If
you search for "grid" you will find multiple algorithms under
GDAL/Raster analysis.  See
https://gdal.org/tutorials/gdal_grid_tut.html#gdal-grid-tut and
https://gdal.org/programs/gdal_grid.html  for other methods. This should
cover it.
The idea is generally to interpolate a raster surface from points or
lines containing a z field or a z value (in 3D files).  After, you use
Raster/Extract/Contour on this new raster layer.  You can also install
the contour plugin.  That uses a point file only but I don't know the
what algorithm it uses.
You may find more algorithm using CrimeStat or GeoDa softwares.
Hope this helps.
Nicolas
On 2021-12-06 1:59 p.m., Firstname Lastname wrote:
> hello group:
> i want to demonstrate some of the pitfalls of computer contouring
> methods with limited datasets.  i wanted to use a small dataset to
> demonstrate several contouring algorithms. In particular, linear
> interpolation, inverse weighted, nearest neighbour and kriging.  Are
> any of these built into QGIS?  i do not see any options to control the
> contouring in the plugins for any options other than the default.
> thank you if you can provide any help.
> Byron Veilleux, MSc. P.Geo
> Conjugate Geologic Services Limited
> Calgary, Alberta Canada
> byron at conjugategeo.com
> Cell:4037108414
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211206/6744d82c/attachment.html>
