[Qgis-user] startup.py on network folder
Thomas Schüttenberg thomas at qgis.de
Wed Dec 8 01:53:27 PST 2021
another work around is explained here: https://gis.stackexchange.com/questions/319224/central-deployment-of-startup-py-in-qgis/319225
Regards
Thomas
> Wolfgang Meinolf <wmeinolf at bbv-deutschland.de> hat am 06.12.2021 18:02 geschrieben:
> Hi Stefan,
> thks for the fast response. That’s something, I can build on.
> Br
> Wolfgang
> Von: Stefan Giese (WhereGroup) <stefan.giese at wheregroup.com>
>  Gesendet: Montag, 6. Dezember 2021 17:35
>  An: Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>; qgis-user <Qgis-user at lists.osgeo.org>
>  Betreff: Re: [Qgis-user] startup.py on network folder
> Hi Wolfgang,
> you can start QGIS with a command line option --codefollowed by the path and scriptname, for example in a BAT file
> Best regards
> stefan
> Am 06.12.2021 um 17:31 schrieb Wolfgang Meinolf:
> > Hi,
> > I like to implement a centrally controlled QGIS environment for our workforce using startup.py. Is there any trick, to put startup.py on a network folder instead the user’s QGIS folder i.e. under Windows %user%\AppData\Roaming\QGIS\QGIS3?
> > PYQGIS_STARTUP environment variable to change the location does unfortunately not work.
> > Thanks
> > Wolfgang
> > Qgis-user mailing list
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufwind durch Wissen!
> Jetzt neu: Webinare und Online-Schulungen
> bei der www.foss-academy.com (http://www.foss-academy.com)
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> www.wheregroup.com (http://www.wheregroup.com)
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
