[Qgis-user] startup.py on network folder
Wolfgang Meinolf wmeinolf at bbv-deutschland.de
Mon Dec 6 09:02:22 PST 2021
Hi Stefan,
thks for the fast response. That’s something, I can build on.
Br
Wolfgang
Von: Stefan Giese (WhereGroup) <stefan.giese at wheregroup.com>
Gesendet: Montag, 6. Dezember 2021 17:35
An: Wolfgang Meinolf <wmeinolf at bbv-deutschland.de>; qgis-user <Qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] startup.py on network folder
Hi Wolfgang,
you can start QGIS with a command line option --code followed by the path and scriptname, for example in a BAT file
Best regards
stefan
Am 06.12.2021 um 17:31 schrieb Wolfgang Meinolf:
I like to implement a centrally controlled QGIS environment for our workforce using startup.py. Is there any trick, to put startup.py on a network folder instead the user’s QGIS folder i.e. under Windows %user%\AppData\Roaming\QGIS\QGIS3?
PYQGIS_STARTUP environment variable to change the location does unfortunately not work.
Thanks
Wolfgang
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Webinare und Online-Schulungen
bei der www.foss-academy.com<http://www.foss-academy.com>
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com<mailto:stefan.giese at wheregroup.com>
www.wheregroup.com<http://www.wheregroup.com>
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211206/401f6da0/attachment.html>
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211206/401f6da0/attachment.bin>
