[Qgis-user] startup.py on network folder
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Mon Dec 6 08:35:20 PST 2021
Hi Wolfgang,
you can start QGIS with a command line option *--code *followed by the
path and scriptname, for example in a BAT file
Best regards
stefan
Am 06.12.2021 um 17:31 schrieb Wolfgang Meinolf:
> Hi,
> I like to implement a centrally controlled QGIS environment for our
> workforce using startup.py. Is there any trick, to put startup.py on a
> network folder instead the user’s QGIS folder i.e. under Windows
> %user%\AppData\Roaming\QGIS\QGIS3?
> PYQGIS_STARTUP environment variable to change the location does
> unfortunately not work.
> Thanks
> Wolfgang
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Webinare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211206/f27c19e4/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211206/f27c19e4/attachment.sig>
