[Qgis-user] Newby question on mapping information
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Dec 9 09:51:02 PST 2021
from what I read and understand:
1. "with separate layers for boundaries of each plot and unique" If I
understand this correctly, every polygon has a unique layer?
Then Processing -> Toolbox -> Merge vector layers
If I understood this wrong, skip this step.
2. Toolbox -> Join attributes by field value -> Pick your boundaries
layer and the csv and set the common field
3. Layer properties -> Symbology -> Change from Single Symbol to
Categorized -> pick a field from which you can distinct the ownership ->
Classify
Good luck
Am 09.12.21 um 17:57 schrieb Miro Lucassen:
> Hi, this is probably easy for experienced users, but I am stuck in the interface as this is my first project in QGIS.
> Aim of project: map of a part of an Dutch municipal authority, marked areas that are owned by the local authorities.
> Input 1: KML-file of all registered property (kadaster) in the relevant area plus a bit more, with separate layers for boundaries of each plot and unique ID, including geo-information
> Input 2: CSV-file of all property owned by the Municipality in the relevant area plus a bit more, with same ID as the general KML-file, no geo-information
> I see the map of all property, I have imported the municipality-plots as a separate layer, but now what? How do I connect the relevant property to the map, and how do I create a visualisation that shows the plots owned by the Municipality?
> Any help is greatly appreciated.
> Miro Lucassen,
> The Netherlands
> Qgis-user mailing list
