[Qgis-user] Newby question on mapping information
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Thu Dec 9 11:04:16 PST 2021
Miro,
may be you have a look to that and other tutorials from Ujaval, where
some steps mentioned by Bernd are explained:
http://www.qgistutorials.com/en/docs/3/performing_table_joins.html
Best regards
Stefan
Am 09.12.2021 um 18:51 schrieb Bernd Vogelgesang:
> Hi,
> from what I read and understand:
> 1. "with separate layers for boundaries of each plot and unique" If I
> understand this correctly, every polygon has a unique layer?
> Then Processing -> Toolbox -> Merge vector layers
> If I understood this wrong, skip this step.
> 2. Toolbox -> Join attributes by field value -> Pick your boundaries
> layer and the csv and set the common field
> 3. Layer properties -> Symbology -> Change from Single Symbol to
> Categorized -> pick a field from which you can distinct the ownership ->
> Classify
> Good luck
> Am 09.12.21 um 17:57 schrieb Miro Lucassen:
>> Hi, this is probably easy for experienced users, but I am stuck in
>> the interface as this is my first project in QGIS.
>> Aim of project: map of a part of an Dutch municipal authority, marked
>> areas that are owned by the local authorities.
>> Input 1: KML-file of all registered property (kadaster) in the
>> relevant area plus a bit more, with separate layers for boundaries of
>> each plot and unique ID, including geo-information
>> Input 2: CSV-file of all property owned by the Municipality in the
>> relevant area plus a bit more, with same ID as the general KML-file,
>> no geo-information
>> I see the map of all property, I have imported the municipality-plots
>> as a separate layer, but now what? How do I connect the relevant
>> property to the map, and how do I create a visualisation that shows
>> the plots owned by the Municipality?
>> Any help is greatly appreciated.
>> Miro Lucassen,
>> The Netherlands
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Webinare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211209/25149d73/attachment.sig>
