[Qgis-user] Buffer by Attribute Issue
Richard Duivenvoorde
rdmailings at duif.net
Thu Dec 16 07:19:21 PST 2021
On 12/16/21 16:08, Peter Devanney wrote:
> Chris
> The buffer input is a point the lat and long are Doubles. The buffer distance variable is a Double. Using EPSG 3857 for all.
So your data is in lat/lon so in degrees?
Or in EPSG:3857 units (more or less meters)?
Can you show the coordinates of your point layer (also EPSG:3857 ?)
What if you select/copy one point, does it look like (a point in NL)
wkt_geom
Point (542953.32029126526322216 6792876.35233329329639673)
or
wkt_geom
Point (5.50943334180317645 52.15814766031191851)
> Not sure what the protocol on the list is or if it will accept a small 2 MB .mp4 but I can show what I am doing for workflow if that might help?
Nope, I think attachments > 75kB are removed or held back
Regards,
Richard
