[Qgis-user] Buffer by Attribute Issue
Peter Devanney peter at devanney.ca
Thu Dec 16 10:56:01 PST 2021
Example point in the project CRS ( EPSG:3857) -11923424,5461258
I have had the buffer problem with a GCS like but just usually convert to a
UTM to do analysis.
I was using a pseudo mercator here because the web maps are in that CRS and
don't distort as a base map for a quick view of some data. Buffer works
with a fixed distance specified in the Buffer dialog; but not when I try to
use an attribute from the table as a buffer distance variable.
thanks
Peter
On Thu, Dec 16, 2021 at 10:19 AM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 12/16/21 16:08, Peter Devanney wrote:
> > Chris
> > The buffer input is a point the lat and long are Doubles. The buffer
> distance variable is a Double. Using EPSG 3857 for all.
> So your data is in lat/lon so in degrees?
> Or in EPSG:3857 units (more or less meters)?
> Can you show the coordinates of your point layer (also EPSG:3857 ?)
> What if you select/copy one point, does it look like (a point in NL)
> wkt_geom
> Point (542953.32029126526322216 6792876.35233329329639673)
> or
> wkt_geom
> Point (5.50943334180317645 52.15814766031191851)
> > Not sure what the protocol on the list is or if it will accept a small 2
> MB .mp4 but I can show what I am doing for workflow if that might help?
> Nope, I think attachments > 75kB are removed or held back
> Regards,
> Richard
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211216/2062d155/attachment.html>
