[Qgis-user] adding a simple filled polygon
Johan De Groote Johan.de.groote at quirinus.one
Fri Dec 17 02:10:08 PST 2021
Hello, I'm new to QGIS (and gis in general). For the job I need to make events logged form a GPS visible on a map. The events are when we enter or leave a zone defined as a polygon.
I managed to get the openstreet view in the background and each type of events (entering and leaving) on a separate layer. This worked fine following a tutorial I found on the net. Just what I need.
But now I want to enter the zones. These are defined as polygons with each cornerpoint defined by GPS coordinates. I have already set those points on a separate layer. Now I read the handbook but it is not very clear. It starts with adding a new shape layer (ok). But then it gets very muddly for me. I tried a tutorial but this is for older versions of QGIS (just as the training manual on the QGIS website) and they talk about "click the add a polygon icon" which isn't to be found.
So is there somewher a tutorial on how to add a filled polygon on a map when you have the points as GPS coordinates? I can add the polygon capturing the points on the map, that kind of precision is acceptable for my needs.
Thanks,
Johan
Using:
QGIS version
3.22.0-Białowieża
QGIS code branch
Release 3.22
Qt version
5.15.2
Python version
3.9.9
GDAL/OGR version
3.3.3
PROJ version
8.2.0
EPSG Registry database version
v10.038 (2021-10-21)
GEOS version
3.10.0-CAPI-1.16.0
SQLite version
3.35.5
PostgreSQL client version
No support
SpatiaLite version
5.0.1
QWT version
6.1.5
QScintilla2 version
2.11.6
OS version
Gentoo/Linux
