[Qgis-user] adding a simple filled polygon
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Dec 17 03:04:18 PST 2021
from what I understand, you just need to make your new layer editable
(pencil symbol), then you can see the symbol for adding a polygon.
Besides that: Be aware that the original coordinate system of GPS points
is EPSG 4326 (unit degrees), and so is the default CRS for layers in
QGIS. In case you want to do more sophisticated operations later with
your data, you should reproject them to a local metric coordinate
system. Tricky topic for beginners. The toolbox is your friend.
Cheers,
Bernd
Am 17.12.21 um 11:10 schrieb Johan De Groote:
> Hello, I'm new to QGIS (and gis in general). For the job I need to make events logged form a GPS visible on a map. The events are when we enter or leave a zone defined as a polygon.
> I managed to get the openstreet view in the background and each type of events (entering and leaving) on a separate layer. This worked fine following a tutorial I found on the net. Just what I need.
> But now I want to enter the zones. These are defined as polygons with each cornerpoint defined by GPS coordinates. I have already set those points on a separate layer. Now I read the handbook but it is not very clear. It starts with adding a new shape layer (ok). But then it gets very muddly for me. I tried a tutorial but this is for older versions of QGIS (just as the training manual on the QGIS website) and they talk about "click the add a polygon icon" which isn't to be found.
> So is there somewher a tutorial on how to add a filled polygon on a map when you have the points as GPS coordinates? I can add the polygon capturing the points on the map, that kind of precision is acceptable for my needs.
> Thanks,
> Johan
> Using:
> QGIS version
> 3.22.0-Białowieża
> QGIS code branch
> Release 3.22
> Qt version
> 5.15.2
> Python version
> 3.9.9
> GDAL/OGR version
> 3.3.3
> PROJ version
> 8.2.0
> EPSG Registry database version
> v10.038 (2021-10-21)
> GEOS version
> 3.10.0-CAPI-1.16.0
> SQLite version
> 3.35.5
> PostgreSQL client version
> No support
> SpatiaLite version
> 5.0.1
> QWT version
> 6.1.5
> QScintilla2 version
> 2.11.6
> OS version
> Gentoo/Linux
> Qgis-user mailing list
