[Qgis-user] sry for greenhorn problem...
Christoph Jung
jagodki.cj at gmail.com
Tue Mar 2 12:33:31 PST 2021
Hello Helen,
I installed the plugin for trying to reproduce your problem. I noticed, that the plugin needs to download additional data after installing it via plugin manager. After cancelling this download I received a similar, but not the same, error like you. Did you downloaded the additional stuff after installing the plugin?
Maybe it would be better to create a new issue with your question at the Github repository of the plugin to address your question directly to the plugin author.
Greetings,
Christoph
> Am 02.03.2021 um 18:02 schrieb Helen Willems <willems.helen at googlemail.com>:
> Dear experts!
> I think I have a real "greenhorn problem", but nevertheless can´t solve it on my own...
> I used to work with QGIS 3.10 and wanted to use the UMEP Plugin, but following error message occured:
> Ein Fehler trat bei der Ausführung von Python-Code auf:
> RuntimeError: module compiled against API version 0xe but this version of numpy is 0xd
> Python-Version: 3.7.3 (default, Mar 27 2019, 09:23:15) [Clang 10.0.1 (clang-1001.0.46.3)]
> QGIS-Version: 3.10.4-A Coruña A Coruña, 10bc9f2ff2
> Python-Pfad:
> /Users/helenwillems/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/geometric_attributes
> /Applications/QGIS3.10.app/Contents/MacOS/../Resources/python
> /Applications/QGIS3.10.app/Contents/MacOS/../Resources/python/plugins
> /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages/geos
> /Applications/QGIS3.10.app/Contents/Resources/python
> /Users/helenwillems/Library/Python/3.7/lib/python/site-packages
> /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
> /Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
> Then I updated QGIS to QGIS-LTR (3.16.4) and tried to install the UMEP plugin again, but then this error message poped up:
> Konnte Erweiterung 'UMEP' nicht laden aufgrund eines Fehlers beim Aufruf der classFactory() Methode
> ModuleNotFoundError: No module named 'osr'
> Traceback (most recent call last):
> File "/Applications/QGIS-LTR.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 334, in _startPlugin
> plugins[packageName] = package.classFactory(iface)
> File "/Users/helenwillems/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/UMEP/__init__.py", line 34, in classFactory
> from .UMEP import UMEP
> File "/Applications/QGIS-LTR.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 792, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/Users/helenwillems/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/UMEP/UMEP.py", line 42, in
> from .UMEPDownloader.umep_downloader import UMEP_Data_Download
> File "/Users/helenwillems/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/UMEP/UMEPDownloader/umep_downloader.py", line 41, in
> import osr
> Python-Version: 3.8.7 (default, Feb 10 2021, 09:04:08) [Clang 12.0.0 (clang-1200.0.32.29)]
> QGIS-Version: 3.16.4-Hannover Hannover, 81ba6c0826
> Python-Pfad:
> /Applications/QGIS-LTR.app/Contents/MacOS/../Resources/python/plugins
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/click_plugins-1.1.1-py3.8.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/patsy-0.5.1-py3.8.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/cftime-1.2.1-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/pandas-1.1.0-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/geopandas-0.8.1-py3.8.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/GDAL-3.2.1-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/Rtree-0.9.4-py3.8.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/matplotlib-3.3.0-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/rasterio-1.1.5-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/netCDF4-1.5.4-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/Pillow-7.2.0-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/scipy-1.5.1-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/affine-2.3.0-py3.8.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/numba-0.50.1-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/opencv_contrib_python-4.3.0.36-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python38.zip
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/numpy-1.20.1-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/pyproj-2.6.0-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/snuggs-1.4.7-py3.8.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/Fiona-1.8.13.post1-py3.8-macosx-10.13.0-x86_64.egg
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/lib-dynload
> /Applications/QGIS-LTR.app/Contents/MacOS/lib/python3.8/site-packages/statsmodels-0.11.1-py3.8-macosx-10.13.0-x86_64.egg
> Can anybody help me?
> I am really not an qgis expert, so would be pleased if someone could try to help me in lets say "easy wording"?!
> Hope to get some help! thx in advance..
> Helen
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210302/25cf875e/attachment.html>
