[Qgis-user] Create circle with diameter in QGIS
C Hamilton adenaculture at gmail.com
Fri Mar 12 06:27:38 PST 2021
Dear Madeline,
If you want to start with a point layer representing the center of the
circle, then you can use the Shape Tools plugin to create either a geodesic
ellipse or donut about the point. If you use the donut, just set the inner
radius to 0 and the outer radius to 37.5 meters. You can also pull the
radius you want to use from the attribute table. In QGIS there are multiple
ways to accomplish what you want to do so just pick what works easiest for
you.
Calvin
On Fri, Mar 12, 2021 at 8:09 AM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Madeline,
> You need to enable the "Advanced Digitizing mode/panel". See
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#the-advanced-digitizing-panel
> for details.
> The shortcut "d" (distance) is your friend. When this mode is activated
> you can enter distances (like your radius) with the keyboard and QGIS will
> constrain to these values.
> You need to invest a bit of time to understand all the construction modes,
> but once you get it, it is quite powerful.
> Greetings,
> Andreas
> On 2021-03-12 13:37, Madeline Krohn wrote:
> Dear QGIS Team,
> I would like to create a circle whose diameter is 75 metres. I am using
> QGIS version 3.16.3-Hannover.
> My procedure so far has been like this:
> 1. create a new shapefile layer -> geometry type: polygon
> 2. in edit mode of this layer: add circle with centre and another point
> --> How can I change the radius/diameter of the circle afterwards or is
> there another possibility to create a circle with diameter directly?
> Thank you very much and best regards
> Madeline
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/991b46b9/attachment.html>
