[Qgis-user] qgis server osgeo4w64 noobs question qgis server
Jorge Gustavo Rocha jgr at geomaster.pt
Fri Mar 12 12:25:06 PST 2021
Hi Marc,
Can you ask a more specific question? I'm sorry, but for someone like me
that knows nothing about you attempts, it is difficult to help.
Is QGIS Server running or not? If not, what is the problem?
QGIS Server reads *.qgz project files. That's for sure and you will not
find nothing that says it can't. QGIS Server reads the same project
formats as QGIS Desktop.
How are you testing it? Are you writing manually the calls to the
services or are you using some client (like QGIS Desktop)? You can debug
QGIS Server using QGIS Desktop as client.
Regards,
Jorge Gustavo
Às 12:39 de 12/03/21, Marc Millas escreveu:
> Nobody on this??
> I need help
> Thanks
> Le jeu. 11 mars 2021 à 17:27, Marc Millas <marc.millas at mokadb.com
> <mailto:marc.millas at mokadb.com>> a écrit :
>     Hi, I just reinstall a full osgeo4W64 distro on a w10 machine.
>     (with qgis 3.16.4)
>     I have created 2 simple projects with qgis desktop
>     1) with only an osm standard map
>     2) with the same map+ 2 layers out of postgres12//postgis3.1  one
>     layer polygon ; one layer  point
>     I do setup the project qgisserver properties, so as to limit the
>     size of the map , ...
>     I have a fresh, working, apache24 installed on the same w10
>     machine (apache lounge distro)
>     So, I try to follow some docs to test the qgisserver capabilities.
>     I modified the http.conf file, and run the WMS getcapabilities
>     test suggested in the doc. fine, I get an xml doc stating various
>     things. ok.
>     Then I try the getmap test using my just created qgis projects.
>     1) looks like that 3xx version of qgis server dont know the qgz
>     format. So back to qgis to save each project in a qgs format. (I
>     found nothing  in the doc about this)
>     2) now when I run the getmap test out of the same browser, I get a
>     white rectangle of the size asked for in the getmap request, in a
>     wholly black landscape.
>     -looking at apache log, I found for each test a set of errors
>     coming from qgis-mapserv.fcgi.exe saying that the .exe didnt found
>     proj.db
>     after a little internet digging, I did setup PROJ_LIB pointing to
>     the C:\OSGeo4W64\share\proj
>     directory where the osgeo installer put the proj.db file
>     Rerun the getmap test.
>     nothing changes.
>     also if I run the getmap request with the qgis-server instead of
>     the qgis_mapserv.fcgi.exe tool, I get a simple "url not found"
>     apache message.
>     looks like I need some help
>     thanks,
>     regards,
>     Marc MILLAS
>     Senior Architect
>     +33607850334
>     www.mokadb.com <http://www.mokadb.com>
> Qgis-user mailing list
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Jorge Gustavo Rocha* | Software Engineer
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
*g:*41.54094,-8.40490 | *v: *510 906 109
*a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/34923969/attachment.html>
