[Qgis-user] qgis server osgeo4w64 noobs question qgis server
Marc Millas marc.millas at mokadb.com
Fri Mar 12 13:58:44 PST 2021
Hi Jorge,
I did try to describe what I did as much precisely as I can.
w10 machine with a qgis desktop 3.16.4 which run fine.
a postgres12/postgis3.1 DB
No pb to display a map (like osm standard) and to add layers out of the
postgres DB within the qgis desktop.
What I try to POC is qgis server. So, I install osgeo4W64 with all options,
and try to follow the doc:
setup the http.conf of an apache2.4
and then run requests from a chrome or mozilla browser.
you ask "is qgis server running ?"
I reread the doc and found nowhere this.
Also, in the osgeo4W64/bin  directory nothing like a qgisserver.exe (or
similar)file
neither in the osgeo4W64/app/qgis/bin directory
So, please, can you explain what you mean ?
thanks
Marc MILLAS
Senior Architect
+33607850334
www.mokadb.com
On Fri, Mar 12, 2021 at 9:25 PM Jorge Gustavo Rocha <jgr at geomaster.pt>
wrote:
> Hi Marc,
> Can you ask a more specific question? I'm sorry, but for someone like me
> that knows nothing about you attempts, it is difficult to help.
> Is QGIS Server running or not? If not, what is the problem?
> QGIS Server reads *.qgz project files. That's for sure and you will not
> find nothing that says it can't. QGIS Server reads the same project formats
> as QGIS Desktop.
> How are you testing it? Are you writing manually the calls to the services
> or are you using some client (like QGIS Desktop)? You can debug QGIS Server
> using QGIS Desktop as client.
> Regards,
> Jorge Gustavo
> Às 12:39 de 12/03/21, Marc Millas escreveu:
> Nobody on this??
> I need help
> Thanks
> Le jeu. 11 mars 2021 à 17:27, Marc Millas <marc.millas at mokadb.com> a
> écrit :
>> Hi, I just reinstall a full osgeo4W64 distro on a w10 machine. (with qgis
>> 3.16.4)
>> I have created 2 simple projects with qgis desktop
>> 1) with only an osm standard map
>> 2) with the same map+ 2 layers out of postgres12//postgis3.1  one layer
>> polygon ; one layer  point
>> I do setup the project qgisserver properties, so as to limit the size of
>> the map , ...
>> I have a fresh, working, apache24 installed on the same w10 machine
>> (apache lounge distro)
>> So, I try to follow some docs to test the qgisserver capabilities.
>> I modified the http.conf file, and run the WMS getcapabilities test
>> suggested in the doc. fine, I get an xml doc stating various things. ok.
>> Then I try the getmap test using my just created qgis projects.
>> 1) looks like that 3xx version of qgis server dont know the qgz format.
>> So back to qgis to save each project in a qgs format. (I found nothing  in
>> the doc about this)
>> 2) now when I run the getmap test out of the same browser, I get a white
>> rectangle of the size asked for in the getmap request, in a wholly black
>> landscape.
>> -looking at apache log, I found for each test a set of errors coming from
>> qgis-mapserv.fcgi.exe saying that the .exe didnt found proj.db
>> after a little internet digging, I did setup PROJ_LIB pointing to
>> the C:\OSGeo4W64\share\proj
>> directory where the osgeo installer put the proj.db file
>> Rerun the getmap test.
>> nothing changes.
>> also if I run the getmap request with the qgis-server instead of the
>> qgis_mapserv.fcgi.exe tool, I get a simple "url not found" apache message.
>> looks like I need some help
>> thanks,
>> regards,
>> Marc MILLAS
>> Senior Architect
>> +33607850334
>> www.mokadb.com
> Qgis-user mailing listQgis-user at lists.osgeo.org
> [image: Logo] <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:* jgr at geomaster.pt | *m:* +351 910 333 888
> *g:* 41.54094,-8.40490 | *v: * 510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210312/9a9f273b/attachment.html>
