[Qgis-user] Questões sobre o QGIS 3.22.5
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sat Apr 2 07:05:40 PDT 2022
Ah,
I first understood , that QGIS crashes with this error message.
Obviously, only the error message appears.
To get rid of the message, just deactivate the plugin
-> deepl.com ...
Am 02.04.22 um 15:59 schrieb Bernd Vogelgesang via Qgis-user:
>> I have installed QGIS 3.22-1, on Windows 64 bits Operating System.
>> The version installed is Standlone.
>> When I start the Program this message appears:
>> Python Error: Unable to load complement 'ProfileFromPoints' Due to an
>> error calling the Class Factory() method.
>> Please, how can I solve this?
> https://www.deepl.com/translator#pt/en/Instalei%20o%20QGIS%203.22-1%2C%20no%20Sistema%20Operacional%20Windows%2064%20bits.%20A%20vers%C3%A3o%20instalada%20%C3%A9%20a%20Standlone.%0A%0AQuando%20inicio%20o%20Programa%20aparece%20esta%20mensagem%3A%0A%0AErro%20Python%3A%20Imposs%C3%ADvel%20carregar%20complemento%20'ProfileFromPoints'%20Devido%20a%20um%20erro%20ao%20chamar%20o%20m%C3%A9todo%20Class%20Factory().%0A%0APor%20favor%2C%20como%20fa%C3%A7o%20para%20solucionar%20isso%3F
> From the message you received it indicates, that the plugin
> "ProfileFromPoints" causes problems.
> The easiest method to get rid of that problem, is to search for the
> plugin's folder in the users directory, and to delete it.
> At restart, the plugin will not be loaded, so the problem should be
> solved.
> The path to the folder is something like
> QGIS3\profiles\default\python\plugins
> Da mensagem que recebeu indica que o plugin "ProfileFromPoints" causa
> problemas.
> O método mais fácil para se livrar desse problema, é procurar a pasta
> do plugin no directório de utilizadores, e apagá-la.
> No reinício, o plugin não será carregado, pelo que o problema deve ser
> resolvido.
> O caminho para a pasta é algo semelhante a
> Am 02.04.22 um 15:29 schrieb Julio Caetano Tomazoni via Qgis-user:
>> *Instalei o QGIS 3.22-1, no Sistema Operacional Windows 64 bits. A
>> versão instalada é a Standlone.*
>> *Quando inicio o Programa aparece esta mensagem:*
>> *Erro Python: *Impossível carregar complemento 'ProfileFromPoints'
>> Devido a um erro ao chamar o método Class Factory().
>> Por favor, como faço para solucionar isso?
>> Geógrafo, Especialista em Cartografia e Georreferenciamento Rural
>> Mestre e Doutor em geologia
>> Pós-Doutor em Química
>> Telefone 46 999756312
>> caetano at utfpr.edu.br
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220402/1b7694c0/attachment.html>
