[Qgis-user] Questões sobre o QGIS 3.22.5
Nicolas Cadieux njacadieux.gitlab at gmail.com
Sat Apr 2 10:51:55 PDT 2022
Yes,
Profile from point is a plugin right?  Updating that plugin would help.  You could delete it or create a new profile.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 2 avr. 2022 à 10:06, Bernd Vogelgesang via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Ah,
> I first understood , that QGIS crashes with this error message.
> Obviously, only the error message appears.
> To get rid of the message, just deactivate the plugin
> -> deepl.com ...
> Am 02.04.22 um 15:59 schrieb Bernd Vogelgesang via Qgis-user:
>>> I have installed QGIS 3.22-1, on Windows 64 bits Operating System. The version installed is Standlone.
>>> When I start the Program this message appears:
>>> Python Error: Unable to load complement 'ProfileFromPoints' Due to an error calling the Class Factory() method.
>>> Please, how can I solve this?
>> https://www.deepl.com/translator#pt/en/Instalei%20o%20QGIS%203.22-1%2C%20no%20Sistema%20Operacional%20Windows%2064%20bits.%20A%20vers%C3%A3o%20instalada%20%C3%A9%20a%20Standlone.%0A%0AQuando%20inicio%20o%20Programa%20aparece%20esta%20mensagem%3A%0A%0AErro%20Python%3A%20Imposs%C3%ADvel%20carregar%20complemento%20'ProfileFromPoints'%20Devido%20a%20um%20erro%20ao%20chamar%20o%20m%C3%A9todo%20Class%20Factory().%0A%0APor%20favor%2C%20como%20fa%C3%A7o%20para%20solucionar%20isso%3F
>> From the message you received it indicates, that the plugin  "ProfileFromPoints" causes problems.
>> The easiest method to get rid of that problem, is to search for the plugin's folder in the users directory, and to delete it.
>> At restart, the plugin will not be loaded, so the problem should be solved.
>> The path to the folder is something like QGIS3\profiles\default\python\plugins
>> Da mensagem que recebeu indica que o plugin "ProfileFromPoints" causa problemas.
>> O método mais fácil para se livrar desse problema, é procurar a pasta do plugin no directório de utilizadores, e apagá-la.
>> No reinício, o plugin não será carregado, pelo que o problema deve ser resolvido.
>> O caminho para a pasta é algo semelhante a QGIS3\profiles\default\python\plugins
>> Am 02.04.22 um 15:29 schrieb Julio Caetano Tomazoni via Qgis-user:
>>> Instalei o QGIS 3.22-1, no Sistema Operacional Windows 64 bits. A versão instalada é a Standlone.
>>> Quando inicio o Programa aparece esta mensagem:
>>> Erro Python: Impossível carregar complemento 'ProfileFromPoints' Devido a um erro ao chamar o método Class Factory().
>>> Por favor, como faço para solucionar isso?
>>> Geógrafo, Especialista em Cartografia e Georreferenciamento Rural
>>> Mestre e Doutor em geologia
>>> Pós-Doutor em Química
>>> Telefone 46 999756312
>>> caetano at utfpr.edu.br
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220402/2c44042e/attachment.html>
