[Qgis-user] create PostGIS view from QGis layer
Raymond Nijssen r.nijssen at terglobo.nl
Thu Apr 28 05:38:05 PDT 2022
Hi Gert-Jan,
Not sure how exactly you are filtering your data, but to create views
you can run these queries on your PostgreSQL database using the tool you
like (for example DB-manager in QGIS, or DBeaver or PGAdmin).
In case this is an SQL query filter:
CREATE VIEW blabla1 AS
[your sql select query goes here]
In case it's a 'provider object filter' (in the Source tab of your layer
properties):
CREATE VIEW view_name AS
SELECT * FROM table_name WHERE
[your filter goes here]
Hope this helps,
Raymond
On 28-04-2022 14:09, gisnederland via Qgis-user wrote:
> Hi all,
> I've got a QGis (3.20) project with (amongst others) 15 layers that all
> point to 1 postgis table, but all have a different filter applied (in
> QGis).
> I'm looking for a convenient way to convert these layers-with-filter to
> views in PostGIS, in which the SQL "select"-statement matches the QGis
> filter expression.
> Any way to do this in QGis, or with other tooling?
> Kind regards,
> Gert-Jan
> Qgis-user mailing list
