[Qgis-user] create PostGIS view from QGis layer
tim dunlevie tim.dunlevie5 at gmail.com
Thu Apr 28 05:48:35 PDT 2022
You can also use the QGIS database tool from the menu...to get to the SQL
query gui...construct your query through that - add table, add a condition
(where blah = blah)...then you have the ability to create a view in the
postgis database.....rather than writing sql query using pgadmin etc...
On Thu, 28 Apr 2022, 8:38 pm Raymond Nijssen via Qgis-user, <
qgis-user at lists.osgeo.org> wrote:
> Hi Gert-Jan,
> Not sure how exactly you are filtering your data, but to create views
> you can run these queries on your PostgreSQL database using the tool you
> like (for example DB-manager in QGIS, or DBeaver or PGAdmin).
> In case this is an SQL query filter:
> CREATE VIEW blabla1 AS
> [your sql select query goes here]
> In case it's a 'provider object filter' (in the Source tab of your layer
> properties):
> CREATE VIEW view_name AS
> SELECT * FROM table_name WHERE
> [your filter goes here]
> Hope this helps,
> Raymond
> On 28-04-2022 14:09, gisnederland via Qgis-user wrote:
> > Hi all,
> > I've got a QGis (3.20) project with (amongst others) 15 layers that all
> > point to 1 postgis table, but all have a different filter applied (in
> > QGis).
> > I'm looking for a convenient way to convert these layers-with-filter to
> > views in PostGIS, in which the SQL "select"-statement matches the QGis
> > filter expression.
> > Any way to do this in QGis, or with other tooling?
> > Kind regards,
> > Gert-Jan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220428/6805fd76/attachment.html>
