[Qgis-user] create PostGIS view from QGis layer
gisnederland gert-jan at gisnederland.nl
Thu Apr 28 06:15:39 PDT 2022
Hi Tim and Raymond,
Perhaps I'd explain a little more:
The QGis database tool (as Tim suggests) converts my QGis layer
"myLayer" (= a postgis table "myTable" with a QGis filter ("myFilter"
applied to it) to a new postgis *table*
I was hoping to find an (automated!) way to convert the layer to a new
postgis *view*, something like:
   create or replace view "myView"
   as select "myFilter"
   from "myTable"
Kind regards,
Gert-Jan
tim dunlevie via Qgis-user schreef op 28-04-2022 14:48:
> You can also use the QGIS database tool from the menu...to get to the
> SQL query gui...construct your query through that - add table, add a
> condition (where blah = blah)...then you have the ability to create a
> view in the postgis database.....rather than writing sql query using
> pgadmin etc...
> On Thu, 28 Apr 2022, 8:38 pm Raymond Nijssen via Qgis-user,
> <qgis-user at lists.osgeo.org> wrote:
>> Hi Gert-Jan,
>> Not sure how exactly you are filtering your data, but to create
>> views
>> you can run these queries on your PostgreSQL database using the tool
>> you
>> like (for example DB-manager in QGIS, or DBeaver or PGAdmin).
>> In case this is an SQL query filter:
>> CREATE VIEW blabla1 AS
>> [your sql select query goes here]
>> In case it's a 'provider object filter' (in the Source tab of your
>> layer
>> properties):
>> CREATE VIEW view_name AS
>> SELECT * FROM table_name WHERE
>> [your filter goes here]
>> Hope this helps,
>> Raymond
>> On 28-04-2022 14:09, gisnederland via Qgis-user wrote:
>>> Hi all,
>>> I've got a QGis (3.20) project with (amongst others) 15 layers
>> that all
>>> point to 1 postgis table, but all have a different filter applied
>> (in
>>> QGis).
>>> I'm looking for a convenient way to convert these
>> layers-with-filter to
>>> views in PostGIS, in which the SQL "select"-statement matches the
>> QGis
>>> filter expression.
>>> Any way to do this in QGis, or with other tooling?
>>> Kind regards,
>>> Gert-Jan
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
