[Qgis-user] Waiting message displayed in a either QMessageBox or as pushed message does not work
Tudorache, Marian Marian.Tudorache at navcanada.ca
Tue Aug 2 08:54:46 PDT 2022
Hello Community,
In one of pyqgis app built in QGIS 2.18 I have a waiting message to let know the user to wait until a project opens.
I simplified the process in the following scrip:
from qgis.PyQt import QtWidgets
message = "Wait to open the airspace project..."
msg = QtWidgets.QMessageBox()
msg.setText(message)
msg.show()
qgis.utils.iface.messageBar().pushMessage("Wait", message)
for i in range(1000):
    print(i)
qgis.utils.iface.messageBar().pushMessage("Done", "The process is done")
msg.setText("The process is done")
When I run the script as is in QGIS 2.18 the message "Wait to open the airspace project..." is displayed on both message bar and QMessageBox.
Then the loop starts and it display the i.
And at the end the message "The process is done" is displayed in both message bar and QMessageBox.
If I run the same scrip in 3.22.8-Białowieża, the loop starts and no wait message is displayed.
The QMessageBox is somehow displayed without any message.
After the loop is done "The process is done" is displayed in both pushed bar and QMessageBox.
What is strange "The process is done" disappear from the pushed bar and "Wait to open the airspace project..." is displayed.
So this behavior is useless for the user.
Is anyway hot to make QGIS 3.22 to display these messages in the proper sequence as they used to be displayed in QGIS 2.18.
I hope you can access the video at this link. I explained the behavior and you can see it
https://drive.google.com/file/d/1tQNP6nBRL0tAS4bl_2i5heHz7viwCCAv/view?usp=sharing
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y etre joint peuvent contenir des renseignements privilégiés ou confidentiels destinés a l'usage exclusif des personnes ou des organismes a qui ils s'adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l'expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n'assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220802/7fa5ae8b/attachment.htm>
