[Qgis-user] OGC API and paging
Richard Duivenvoorde
rdmailings at duif.net
Tue Aug 2 01:14:38 PDT 2022
On 8/1/22 17:26, nagyrobi_r--- via Qgis-user wrote:
> Hei everybody!
> As far as i see, adding a new OGC-API layer is done much in the same way as adding a WFS layer.
> I just need to sediment some information in my head, so:
> 1. Max number of features would be the number of features that the service would respond even though the number of rows can be larger than the max number of features.
> 2. Page size would then split up the response so one response would only have the number of rows that correspond to page size. For example max number of features is 100, page size is 20, we would then have 5 responses, since 20*5 = 100.
> I was curious, does Enabling feature paging, and setting the page size have any effect on an OGC api?
Hi Robert,
I have the exact same question, after seeing OGC-API client in QGIS only requesting 100 features, instead of paging.
I managed to get paging work (in combination with 'within current view') using PyQGIS partially (no apparent caching or use of ID's, QGIS always requesting/paging ALL features within the view),see
https://github.com/qgis/QGIS/issues/49404
Not sure if this is helpful, I hope someone really into the API will follow up
Regards,
