[Qgis-user] Keypress event and slowless
Andrea Giudiceandrea andreaerdna at libero.it
Thu Aug 4 02:01:36 PDT 2022
> *Jésahel Benoist*
> /Wed Aug 3 23:33:05 PDT 2022/
> Yes, of course, I've tried everything. As I have to test new releases, I
> test with fresh installation too.
So, if you also tried with a new QGIS user profile without any external
plugin installed, this excludes at least that the issue is due to an
external plugin or a non standard QGIS configuration.
Have you searched in the QGIS issue tracker at
https://github.com/qgis/QGIS/issues for any previously reported similar
issue?
If no similar issue is already present, then maybe it is worth to report
the issue there.
Best regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220804/5d5b468b/attachment.htm>
