[Qgis-user] Keypress event and slowless
Jésahel Benoist djes1975 at gmail.com
Thu Aug 4 04:13:56 PDT 2022
> So, if you also tried with a new QGIS user profile without any external
> plugin installed, this excludes at least that the issue is due to an
> external plugin or a non standard QGIS configuration.
> Have you searched in the QGIS issue tracker at
> https://github.com/qgis/QGIS/issues for any previously reported similar
> issue?
> If no similar issue is already present, then maybe it is worth to report
> the issue there.
> Best regards.
> Andrea Giudiceandrea
Yes, I will do it. I usually do prefer asking there before... As there's
some other users, it's ok. For the plugin, there's also integrated plugins,
but you're certainly right.
Thank you
Jésahel
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220804/6ad301b5/attachment.htm>
