[Qgis-user] mdal / mesh simple formats
Delaz J delazj at gmail.com
Thu Aug 25 11:08:35 PDT 2022
Hi Matt,
The mdal repo has a number of mesh data
(https://github.com/lutraconsulting/MDAL/tree/master/tests/data) but
whether these are simple meshes/formats or not is beyond my
understanding of this data type.
Hope that helps,
Harrissou
Le 25/08/2022 à 09:41, Matt Boyd via Qgis-user a écrit :
> Hi QGIS people,
> I asked something like this a couple of years ago, managed to find
> some workarounds and now that I know a little more about what I'm
> doing I could use a bit of help.
> I've got some simple tin meshes that I'd like to drop into QGIS, they
> get generated in a python modelling software I'm using.
> The data all sits in a single hdf5 file, points with coordinates, the
> cells which are just the indexes of 3 points, plus attributes for each
> point. About the simplest mesh setup I can imagine.
> I'm trying to find the simplest format that mdal supports with an
> example dataset so I can make something similar. (ideally hdf5 so I
> don't need to work out how to use anything new in python).
> Any tips?
> Thanks
> Matt
> Qgis-user mailing list
