[Qgis-user] mdal / mesh simple formats
Matt Boyd
mattslists at gmail.com
Thu Aug 25 18:32:34 PDT 2022
Thanks, thats pretty helpful.
I'm running QGIS 3.26.2-Buenos Aires installed from osgeo.
under the xdmf directory there the xmf/hdf files look pretty similar
to what I'm using but they won't load. there's a partial duplicate of
the data in the hdf file in that directory as a 2dm file which does
work.
I'm still not sure if I'm supposed to be able to load the xmf/hdf
files directly using mdal? I can easily drop out my hdf5 data to the
2dm format is this the proposed way to do it?
Thanks again
Matt
On Fri, Aug 26, 2022 at 4:09 AM Delaz J via Qgis-user
<qgis-user at lists.osgeo.org> wrote:
> Hi Matt,
> The mdal repo has a number of mesh data
> (https://github.com/lutraconsulting/MDAL/tree/master/tests/data) but
> whether these are simple meshes/formats or not is beyond my
> understanding of this data type.
> Hope that helps,
> Harrissou
> Le 25/08/2022 à 09:41, Matt Boyd via Qgis-user a écrit :
> > Hi QGIS people,
> > I asked something like this a couple of years ago, managed to find
> > some workarounds and now that I know a little more about what I'm
> > doing I could use a bit of help.
> > I've got some simple tin meshes that I'd like to drop into QGIS, they
> > get generated in a python modelling software I'm using.
> > The data all sits in a single hdf5 file, points with coordinates, the
> > cells which are just the indexes of 3 points, plus attributes for each
> > point. About the simplest mesh setup I can imagine.
> > I'm trying to find the simplest format that mdal supports with an
> > example dataset so I can make something similar. (ideally hdf5 so I
> > don't need to work out how to use anything new in python).
> > Any tips?
> > Thanks
> > Matt
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
