[Qgis-user] mdal / mesh simple formats
Richard Duivenvoorde
rdmailings at duif.net
Thu Aug 25 23:56:20 PDT 2022
Hi Matt,
I'm not a Mesh expert either, but I use (and create) netcdf using python using the
https://github.com/Unidata/netcdf4-python module
Netcdf is pretty good supported in QGIS in my experience
Our data has also a time dimension so we use the CF convention [0] and fiddling around with the so called UGRID convention [1] But maybe that is both too much for a simple tin...
I Googled:
https://stackoverflow.com/questions/48864357/convert-hdf5-to-netcdf4-in-bash-r-python-or-ncl
as being able to convert hdf5 to netcdf... didn't/couldn't try/test though..
Regards,
[0] https://en.wikipedia.org/wiki/Climate_and_Forecast_Metadata_Conventions
[1] http://ugrid-conventions.github.io/ugrid-conventions/#data-variables
On 8/26/22 03:32, Matt Boyd via Qgis-user wrote:
> Thanks, thats pretty helpful.
> I'm running QGIS 3.26.2-Buenos Aires installed from osgeo.
> under the xdmf directory there the xmf/hdf files look pretty similar
> to what I'm using but they won't load. there's a partial duplicate of
> the data in the hdf file in that directory as a 2dm file which does
> work.
> I'm still not sure if I'm supposed to be able to load the xmf/hdf
> files directly using mdal? I can easily drop out my hdf5 data to the
> 2dm format is this the proposed way to do it?
> Thanks again
> Matt
> On Fri, Aug 26, 2022 at 4:09 AM Delaz J via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
>> Hi Matt,
>> The mdal repo has a number of mesh data
>> (https://github.com/lutraconsulting/MDAL/tree/master/tests/data) but
>> whether these are simple meshes/formats or not is beyond my
>> understanding of this data type.
>> Hope that helps,
>> Harrissou
>> Le 25/08/2022 à 09:41, Matt Boyd via Qgis-user a écrit :
>>> Hi QGIS people,
>>> I asked something like this a couple of years ago, managed to find
>>> some workarounds and now that I know a little more about what I'm
>>> doing I could use a bit of help.
>>> I've got some simple tin meshes that I'd like to drop into QGIS, they
>>> get generated in a python modelling software I'm using.
>>> The data all sits in a single hdf5 file, points with coordinates, the
>>> cells which are just the indexes of 3 points, plus attributes for each
>>> point. About the simplest mesh setup I can imagine.
>>> I'm trying to find the simplest format that mdal supports with an
>>> example dataset so I can make something similar. (ideally hdf5 so I
>>> don't need to work out how to use anything new in python).
>>> Any tips?
>>> Thanks
>>> Matt
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
