[Qgis-user] Rendering of Back Ground Image in Map Output
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Dec 2 08:24:59 PST 2022
Assuming we are following Google term of use https://www.google.com/intl/en-GB_ALL/permissions/geoguidelines/ , the easiest way out of this problem is to bypass the Google server when printing as it will effectively limit the number of pixels it feeds you. What I did, in the past was to zoom in, and export the project as an image, pan and then start over again. These .tiff files will be georeferenced. I would then load these file into the project and use those as the background.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 2 déc. 2022 à 03:44, Bibek Rana via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Hello Team,
> I'm using Qgis 3.22 and I am trying to prepare a shape file map with Google Satellite image as background in A1 size paper. I am using 600 dpi and rendering mode Multiply while exporting the map as PDF.
> However, when I zoom in on the output map, the Google Satellite background is heavily pixelated.
> So, can you please provide me with solutions? I've attached the sample image below.
> <image.png>
> Regards,
> Bibek
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221202/b3fb9749/attachment.htm>
