[Qgis-user] Rendering of Back Ground Image in Map Output
Jeff Sonnentag jsonnentag at llenviroinc.com
Fri Dec 2 11:23:05 PST 2022
It may also help to set the Min. and Max. Zoom Level in the XYZ Connections (if that is how you are getting Google Earth, like I am).  These are the setting I use.  It makes loading any large area take a long time, but I am almost always looking at small areas.
[cid:image001.png at 01D90640.71750BB0]
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Nicolas Cadieux via Qgis-user
Sent: Friday, December 2, 2022 8:25 AM
To: Bibek Rana <bibekbikramrana at gmail.com>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Rendering of Back Ground Image in Map Output
Assuming we are following Google term of use https://www.google.com/intl/en-GB_ALL/permissions/geoguidelines/ , the easiest way out of this problem is to bypass the Google server when printing as it will effectively limit the number of pixels it feeds you.   What I did, in the past was to zoom in, and export the project as an image, pan and then start over again.  These .tiff files will be georeferenced.  I would then load these file into the project and use those as the background.
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 2 déc. 2022 à 03:44, Bibek Rana via Qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> a écrit :
Hello Team,
I'm using Qgis 3.22 and I am trying to prepare a shape file map with Google Satellite image as background in A1 size paper. I am using 600 dpi and rendering mode Multiply while exporting the map as PDF.
However, when I zoom in on the output map, the Google Satellite background is heavily pixelated.
So, can you please provide me with solutions? I've attached the sample image below.
<image.png>
Regards,
Bibek
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221202/d09ce040/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221202/d09ce040/attachment-0001.png>
