[Qgis-user] Selecting features of type points with SVG Marker
Tudorache, Marian Marian.Tudorache at navcanada.ca
Fri Dec 2 12:53:25 PST 2022
In QGIS 2.18 I used to apply SVG Marker styles to points and I was able to select these features.
When I executed select, a red square was drawn around the SVG pictogram.
In QGIS3 I still can see these points with SVG marker style but when I select them that red square does not exist anymore.
Basically I cannot make visual difference between selected and unselected features.
Is any setting that I can being back that red square around?
I am using QGIS 3.22.
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le pr?sent message ?lectronique et tout fichier qui peut y ?tre joint peuvent contenir des renseignements privil?gi?s ou confidentiels destin?s ? l'usage exclusif des personnes ou des organismes ? qui ils s'adressent. Si vous avez re?u ce message ?lectronique par erreur, veuillez en informer l'exp?diteur imm?diatement et supprimez le. Toute reproduction, divulgation ou distribution du pr?sent message ?lectronique est strictement interdite. NAV CANADA n'assume aucune responsabilit? en cas de dommage caus? par tout virus ou autre programme malveillant transmis par ce message ?lectronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221202/88190290/attachment.htm>
