[Qgis-user] Colouring Geological Maps
Richard McDonnell richard.mcdonnell at opw.ie
Mon Dec 12 02:17:41 PST 2022
Morning,
I'm not sure if this is a solution for you, but have you considered using attribution and storing your styling requirements as a set of attribute values. You can do this for Fill Colour, Stroke Thickness, Font, Sizes...etc...
You could build a graphic modeller to add the attribution to your data and then have a single default style, which has all the Styling Variables set to use the new attribution.
The only issue with this is that you won't generate a legend...
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poibl?
Office of Public Works
Sr?id Jonathan Swift, Baile ?tha Troim, Co na M?, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Grant Boxer via QGIS-User
Sent: 11 December 2022 08:48
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Colouring Geological Maps
I am trying to find an easier way of colouring a geological map. The only way I can find to colourise the polygons in both the map window and layers panel - and hence the displayed legend - is to use the rule-based rendering option. Each rule has to be manually styled.
Is there a way to get QGIS to interrogate a text file for styling information? I can't seem to find one anywhere in the algorithms. Aiming to use this in a graphical modeller to automate colourising geological maps. I can use a fixed qml file but that has to be done for each individual map unless you have a wide range of set styles.
Cheers Grant, Perth WA
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221212/0e72ab5c/attachment.htm>
More information about the QGIS-User mailing list
