[Qgis-user] Qgis : Create Package (GPK) with custom style and Spatial area?
Francesco Pelullo f.pelullo at gmail.com
Fri Dec 16 09:22:24 PST 2022
by the way, i just finished fighting against the Package Layer toolbox, in
my case the layer style is saved in the geopackage only if you run the
packaging layer algorithm without any previous algorithm. If you need to
store the style in the geopackage, you must run the algorithm package layer
twice, a first time at the start of processing (overwrite geopackage, save
style in geopackage) and a second time at the end of processing (don't
overwrite geopackage, don't save style in geopackage). Otherwise, if you
run  other algorithms before, (like select by attribute, select by position
etc) the style is not saved. Does this happen to you too?
Il ven 16 dic 2022, 17:01 celati Laurent via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> Hello,
> With Qgis 3, With the tool available in "Processing" "Layer packaging",
> package layers within a GeoPackage database by saving the style. But unless
> I am wrong, it does not allow to customize the export to a custom spatial
> Area of Intrest (for example area of the canvas).
> Conversely, via the "layers panel", you can right-click -> export as save
> in a GPK, to a personalized spatial footprint. But at this level, I don't
> feel it's possible to keep the style.
> => Would there be a tool in Qgis combining these 2 possibilities? To
> package in a GPK a selection of layers, to save not only the layers but
> their styles defined in the same personalized extent (for exemple the
> extent of the canvas ? )
> Thanks a lot.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221216/ecb68f73/attachment.htm>
More information about the QGIS-User mailing list
