[Qgis-user] Labeling Lines with Bearings
kirk kirk at nortekresources.com
Thu Feb 3 01:55:52 PST 2022
Hi Spingfield.I use a little routine and the core if it is:main_angle($geometry) which you can use in field calculator.Note this will give you the azimuth in relation to grid north for the coordinate system you are using.  For projections, you will need to lookup or calculate convergence to get the adjustment to true north. Kirk SchmidtSent from my Galaxy
-------- Original message --------From: Springfield Harrison <stellargps at gmail.com> Date: 2022-02-02  7:30 p.m.  (GMT-04:00) To: qgis-user at lists.osgeo.org Subject: [Qgis-user] Labeling Lines with Bearings Hello,I need to put the line direction (azimuth) into a line label. Some searching has not come up with anything.Is there a way?  Thanks very much . . . .--------Cheers, Spring_______________________________________________Qgis-user mailing listQgis-user at lists.osgeo.orgList info: https://lists.osgeo.org/mailman/listinfo/qgis-userUnsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220203/90543671/attachment.html>
