[Qgis-user] Include Comment in source Query
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Feb 3 10:27:48 PST 2022
here are my findings from 2015:
https://gis.stackexchange.com/questions/107522/is-it-possible-to-use-comments-in-qgis-query-builder-with-esri-shapefiles/149448#149448
In short: comments with shape files did not (do not maybe still ) work
Solution: Just do not use ESRI-Shape files for work ;)
Cheers,
Bernd
Am 03.02.22 um 15:33 schrieb Hugh Kelley:
> Very helpful point, it is a shapefile.
> so far "#", "--", "//" and "/* */" did not work. I also tried "<!--
> comment -->" for good measure which didn't work as well.
> I tried a few of those on a geopackage too and they errored out there
> as well.
> I'll try a postgis datas source later today if I remember.
> On Thu, Feb 3, 2022 at 9:23 AM Johannes Kröger (WhereGroup)
> <johannes.kroeger at wheregroup.com> wrote:
> Hi Hugh,
> that depends on the provider in use, a PostGIS provider might
> behave differently from a Shapefile. See if wrapping the comment
> in /* comment */ works.
> Cheers, Hannes
> Am 03.02.22 um 15:16 schrieb Hugh Kelley:
>> Hi all,
>> in the Layer Properties >> source >> Query Builder dialogue, if I
>> use "--" it shows that I've commented out that line. when I test
>> the query though, it throws an error complaining about the
>> comment I included.
>> Is there a way to include a comment in the query?
>> i've like to include a note to myself when I filter things
>> sometimes as it can be hard months or years later to figure out
>> the motivation. for example:
>> -- remove built neighborhood bikeway according to KML file from
>> client, per email 2022-02-03
>> "LOCAL_ID" NOT IN (4030, 3533, 4307, 6015, 5217)
>> Maybe there's a better way to include this note, but it seems
>> that the closer the note is to the filter query definition the
>> more likely I am to see it.
>> thanks
>> Hugh
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Johannes Kröger / GIS-Entwickler/-Berater
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu
Open-Source-GIS-Software
> und berichten aus unserem Experten-Alltag:
> https://wheregroup.com/blog/
> Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220203/f6d074fe/attachment-0001.html>
