[Qgis-user] Include Comment in source Query
Hugh Kelley hghklly at gmail.com
Thu Feb 3 06:33:09 PST 2022
Very helpful point, it is a shapefile.
so far "#", "--", "//" and "/* */" did not work. I also tried "<!-- comment
-->" for good measure which didn't work as well.
I tried a few of those on a geopackage too  and they errored out there as
well.
I'll try a postgis datas source later today if I remember.
On Thu, Feb 3, 2022 at 9:23 AM Johannes Kröger (WhereGroup) <
johannes.kroeger at wheregroup.com> wrote:
> Hi Hugh,
> that depends on the provider in use, a PostGIS provider might behave
> differently from a Shapefile. See if wrapping the comment in /* comment */
> works.
> Cheers, Hannes
> Am 03.02.22 um 15:16 schrieb Hugh Kelley:
> Hi all,
> in the Layer Properties >> source >> Query Builder dialogue, if I use "--"
> it shows that I've commented out that line. when I test the query though,
> it throws an error complaining about the comment I included.
> Is there a way to include a comment in the query?
> i've like to include a note to myself when I filter things sometimes as it
> can be hard months or years later to figure out the motivation. for
> example:
> -- remove built neighborhood bikeway according to KML file from client,
> per email 2022-02-03
> "LOCAL_ID" NOT IN (4030, 3533, 4307, 6015, 5217)
> Maybe there's a better way to include this note, but it seems that the
> closer the note is to the filter query definition the more likely I am to
> see it.
> thanks
> Hugh
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Johannes Kröger / GIS-Entwickler/-Berater
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu
 Open-Source-GIS-Software
> und berichten aus unserem Experten-Alltag:https://wheregroup.com/blog/
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220203/10141a64/attachment.html>
