[Qgis-user] How to make diagonals
Etienne Trimaille etienne.trimaille at gmail.com
Thu Feb 3 23:43:52 PST 2022
Maybe "oriented_bbox" to get first a proper rectangle ?
https://docs.qgis.org/testing/en/docs/user_manual/expressions/functions_list.html#oriented-bbox
But then, you might have some tiny leftover. It depends if you care or not.
Otherwise, you need to use the angle at each points.
I thought there is the longest line possible within a polygon, but I can't
find it. I did it manually a few years ago.
Le jeu. 3 févr. 2022 à 23:29, Dario C <dario955i at gmail.com> a écrit :
> Hi,
> I have several rectangles (almost squared) and I'd like to represent
> their diagonals.
> I started to do with geometry generator with:
> make_line(point_n($geometry,1),point_n($geometry,4))
> and
> make_line(point_n($geometry,2),point_n($geometry,5))
> Unfortunately, even if they look rectangular, actually they have more then
> 4 points and, moreover, points do not always have the same order.
> here below an example:
> [image: image.png]
> Is there any expression in order to pick the two longest segments
> connecting all the points of the geometry?
> Thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220204/a44ea237/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220204/a44ea237/attachment.png>
