[Qgis-user] How to make diagonals
chris hermansen clhermansen at gmail.com
Fri Feb 4 08:32:57 PST 2022
Might generalizing the lines (Poiker Douglas or similar) yield four line
rectangles?
On Thu, Feb 3, 2022, 23:44 Etienne Trimaille <etienne.trimaille at gmail.com>
wrote:
> Maybe "oriented_bbox" to get first a proper rectangle ?
> https://docs.qgis.org/testing/en/docs/user_manual/expressions/functions_list.html#oriented-bbox
> But then, you might have some tiny leftover. It depends if you care or not.
> Otherwise, you need to use the angle at each points.
> I thought there is the longest line possible within a polygon, but I can't
> find it. I did it manually a few years ago.
> Le jeu. 3 févr. 2022 à 23:29, Dario C <dario955i at gmail.com> a écrit :
>> Hi,
>> I have several rectangles (almost squared) and I'd like to represent
>> their diagonals.
>> I started to do with geometry generator with:
>> make_line(point_n($geometry,1),point_n($geometry,4))
>> and
>> make_line(point_n($geometry,2),point_n($geometry,5))
>> Unfortunately, even if they look rectangular, actually they have more
>> then 4 points and, moreover, points do not always have the same order.
>> here below an example:
>> [image: image.png]
>> Is there any expression in order to pick the two longest segments
>> connecting all the points of the geometry?
>> Thanks
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220204/e6f46b7c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220204/e6f46b7c/attachment.png>
