[Qgis-user] Overlapping
Germán Carrillo carrillo.german at gmail.com
Fri Feb 11 16:36:49 PST 2022
Hi Michael,
In line with Harrissou's advice, yesterday I tweeted [1] about an extension
to the "Overlap analysis" in QGIS, which works on exactly 2 layers and is
called "Overlap analysis by class".
The outputs are both overlap area and percentage per class. Perhaps it
could help you.
See installation instructions at [2].
Regards,
Germán
[1] https://twitter.com/GeoTux2/status/1491684612086636547
[2] https://github.com/gacarrillor/QGIS-Resources/#installation
El vie, 11 feb 2022 a las 15:49, Harrissou s. (<delazj at gmail.com>) escribió:
> Hi,
> A starting point can also be the Processing "overlaps analysis" algorithm
> [0] (sorry I don't know how the output actually looks like) followed by
> some aggregate analysis.
> [0]
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectoranalysis.html#overlap-analysis
> Regards,
> Harrissou
> Le 11 février 2022 17:58:00 GMT+01:00, chris hermansen <
> clhermansen at gmail.com> a écrit :
>> Michael and list
>> On Fri, Feb 11, 2022 at 8:49 AM Michael Williamson <
>> michael at michaelandjane.org.uk> wrote:
>>> I am sure this is easy but I can’t work out which facility to use
>>> I have two layers. Layer A is made up of some large polygons while Layer
>>> B is made up of smaller polygons. The Polygons in Layer A overlap one or
>>> more of the polygons in layer B. In most cases the overlap is 100% but
>>> there are a few cases where the overlap is less than that.
>>> Layer B contains population and other data as numerical attributes and I
>>> want to populate corresponding attributes in layer A with the weighted
>>> total of the attributes in layer B depending on the amount of overlap.
>>> I have found various tools but I cannot work out which one to use. The
>>> ones I have found seem to do part of the job but not all of it.
>>> Probably you want
>> Vector > Geoprocessing Tools > Intersection
>> That will give you a new layer C with the geometric intersections of your
>> Layer A and Layer B.  The attribute table for Layer C will contain the
>> attributes of both A and B.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220211/e472f718/attachment.html>
