[Qgis-user] Draw a path by picking heavy density areas
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon Feb 14 07:42:03 PST 2022
You can use the Shortest path analysis available in "Network Analysis".
You may find something in the QNEAT3 plugin.
Perhaps this can help:
https://www.mdpi.com/2306-5729/5/1/8: An article I wrote about using
shortest path analysis
3 models to help debug your road network
https://plugins.qgis.org/models/15/
https://plugins.qgis.org/models/16/
https://plugins.qgis.org/models/17/
A youtube video that explains the models.
Is your directional GIS network driving you crazy?
https://youtu.be/v61PafSByvM <https://youtu.be/v61PafSByvM>
Keep in mind, I was dealing with rivers and not roads with traffic rules.
Nicolas
On 2022-02-14 9:53 a.m., krishna Ayyala wrote:
> Thanks for the reply Nicolas. It needs to follow the roads.
> Regards.
> On Mon, Feb 14, 2022 at 4:57 AM Nicolas Cadieux
> <njacadieux.gitlab at gmail.com> wrote:
> Hi,
> Can you add extra information? What kind on path are you looking
> for? Do you need a path between each point in each area? Do you
> need to follow roads, rivers or is this a straight line of sight
> path?
> You can use the “count points in the polygon” functions found in
> processing to identify what polygon have more points. You could
> generate the “area” of each polygon in the field calculator in
> ordre to figure out the density. Look for “network’ in processing
> and in the plugins to see what is available for path analysis.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 13 févr. 2022 à 19:22, krishna Ayyala
>> <ayyalakrishna at gmail.com> a écrit :
>> Hello,
>> I have a polygon with points as distributed below. Is there a
>> tool in QGIS to draw a path such that the path runs through the
>> heavy population areas? I do not require a path at the least
>> populated areas.
>> Regards.
>> <image.png>
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220214/57d7c6a6/attachment.html>
