[Qgis-user] Draw a path by picking heavy density areas
krishna Ayyala
ayyalakrishna at gmail.com
Mon Feb 14 06:53:33 PST 2022
Thanks for the reply Nicolas. It needs to follow the roads.
Regards.
On Mon, Feb 14, 2022 at 4:57 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Can you add extra information? What kind on path are you looking for? Do
> you need a path between each point in each area? Do you need to follow
> roads, rivers or is this a straight line of sight path?
> You can use the “count points in the polygon” functions found in
> processing to identify what polygon have more points. You could generate
> the “area” of each polygon in the field calculator in ordre to figure out
> the density. Look for “network’ in processing and in the plugins to see
> what is available for path analysis.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 13 févr. 2022 à 19:22, krishna Ayyala <ayyalakrishna at gmail.com> a
> écrit :
> Hello,
> I have a polygon with points as distributed below. Is there a tool in QGIS
> to draw a path such that the path runs through the heavy population areas?
> I do not require a path at the least populated areas.
> Regards.
> <image.png>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220214/e5373b66/attachment.html>
