[Qgis-user] Click and drag files to QGIS 3.22 canvas
Johanna Botman johannab at melton.vic.gov.au
Tue Feb 15 13:11:24 PST 2022
Thanks Ramon for trying to answer,
Yes, what you describe is what has happened in the past. A lot of our data is sent to us in Mid/Mif format and it was this that I was trying to load yesterday when the behaviour changed. I was still able to load shape files and geopackages. The import question arises with these Mid/Mif files. Is there a way to turn that off?
Johanna Botman
Assets / GIS Officer - Melton City Council
Sent: Tuesday, 15 February 2022 7:56 PM
To: Johanna Botman <johannab at melton.vic.gov.au>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Click and drag files to QGIS 3.22 canvas
You don't often get email from custard at westnet.com.au<mailto:custard at westnet.com.au>. Learn why this is important<http://aka.ms/LearnAboutSenderIdentification>
Hi Johanna,
(At least for me) that depends what I'm dropping.
If it's a file type with a single geometry it goes straight in.
For example shp or a zip file with a single shape file inside
If it's a file type with multiple geometries or a container with multiple possibilities then you'll get asked.
For example GPX or zip file with shape and explanatory pdf inside (because there isn't an obvious way of telling if the pdf is georeferenced and you might then want to load it).
Does that help?
Ramon.
On 15 Feb 2022, at 10:44, Johanna Botman <johannab at melton.vic.gov.au<mailto:johannab at melton.vic.gov.au>> wrote:
In the past, I was able to click and drag files from File Explorer on to my QGIS canvas. Today, after installing QGIS 3.22, when I try to do that, I get a dialogue box with Select Items to Add in the header. The beauty of the drag and drop was that it didn't need that confirmation.
Johanna Botman
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Ccfe49629b91b49bb459d08d9f060faf7%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637805121843351922%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000&sdata=zMxLhek09MYiRUG7RWdhzWbr6x4bpFR9seT4aevBkEU%3D&reserved=0>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjohannab%40melton.vic.gov.au%7Ccfe49629b91b49bb459d08d9f060faf7%7C3c254d694e4641f79684759dce781c6a%7C0%7C0%7C637805121843351922%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000&sdata=zMxLhek09MYiRUG7RWdhzWbr6x4bpFR9seT4aevBkEU%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220215/6ba1282b/attachment.html>
