[Qgis-user] linux box accessing project-files on a windows server
Richard Greenwood
richard.greenwood at gmail.com
Mon Feb 21 07:49:55 PST 2022
I did a quick test. I installed QGIS 3.22 on a Windows 7 computer, created
a project. Switched to Linux Mint, used the file manager to navigate to the
Windows computer, double clicked the project and it opened correctly. The
path that QGIS displays in the properties/info panel is:
Path
/run/user/1000/gvfs/smb-share:server=w7,share=c$/Temp/ASSESSOR_ROADS_2018_3.shp
I went back to the Windows computer, exported the shapefile to a gpkg,
saved the project. Reopened it in Mint, all good. QGIS info for the gpkg
layer:
Path
/run/user/1000/gvfs/smb-share:server=w7,share=c$/Temp/test.gpkg
I also tested putting the gpkg in a folder below the project file and
that opened correctly on the Linux computer.
So I suggest that you start with a simple test project. Also, the project
.qgz file is just a gzipped xml file. So you can unzip it, open the .qgs
file in a text editor and search for "source=" to see what path info has
been saved with the project.
Rich
On Mon, Feb 21, 2022 at 3:38 AM Thomas Struller <thomas.struller at lga-geo.de>
wrote:
> Hallo Nicolas,
> thank you for your reply. All my project files are on one network drive
> and I prefer to use geopackages. Perhaps it the problem is, that I install
> qigs from flathub. I’m wondering about that I am the only one who uses qgis
> on linux and want’s to access project-files on a windows file server.
> Mit freundlichen Grüßen
> Thomas Struller
> Diplom Geologe (Univ.), BDG, V18
> *Sachverständiger nach BBodSchG §18,*
> *SG1 Historische Recherche*
> *SG2 Pfad Boden – Gewässer*
> *Akademischer Geoinformatiker*
> Tel: 0049 911 12076 111
> Mobil: 0049 170 33 20 494
> Mail: thomas.struller at LGA-geo.de
> LGA Institut für Umweltgeologie und Altlasten GmbH
> Christian-Hessel-Straße 1
> 90427 Nürnberg
> *info at LGA-geo.de <info at LGA-geo.de>*
> *www.LGA-geo.de <http://www.lga-geo.de/>*
> *Von:* Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> *Gesendet:* Montag, 21. Februar 2022 02:13
> *An:* Thomas Struller <thomas.struller at lga-geo.de>
> *Cc:* qgis-user at lists.osgeo.org
> *Betreff:* Re: [Qgis-user] linux box accessing project-files on a windows
> server
> Hi,
> My guess is that the files you are using are, perhaps, in different
> drives. If you save with a relative path, I think it will work if you have
> files in a simple directory structure but if you have files from multiple
> drives, then perhaps QGIS is forced to uses a drive lettre like c:\ and
> that would not go well on a Linux box.
> Just a guess
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> <https://eu-central-1.protection.sophos.com?d=gitlab.com&u=aHR0cHM6Ly9naXRsYWIuY29tL25qYWNhZGlldXg=&i=NWJmNDNkYTViNDcwM2ExMzMzYzBjODA3&t=STh2Z2tMbmpBYzZGaGFSM2Q4Z1FhSnF6ZFNnRHorTWV6b3VMdXJuZEZVYz0=&h=8d52b2a8b010478e8afd64054f761bba>
> Le 19 févr. 2022 à 06:15, Thomas Struller <thomas.struller at lga-geo.de> a
> écrit :
> Hallo list,
> sometimes I use a linux mint box with qgis 3.22.3. I have to access
> qgis project files over vpn on a windows-fileserver.
> The problem, I can't open these projects. In Qgis (linux-box) i can
> browse to the directory on the windows-fileserver with the qgis-project
> file, but qgis opens a window that shows not available layers. In fact
> no layer of my projet is available. On my windows box I stored the
> project files with relativ project-path and in qgz format.
> What do I not see or what I'm doing wrong?
> Thomas Struller
> 90427 Nürnberg
> info at LGA-geo.de
> www.LGA-geo.de
> <https://eu-central-1.protection.sophos.com?d=lga-geo.de&u=d3d3LkxHQS1nZW8uZGU=&i=NWJmNDNkYTViNDcwM2ExMzMzYzBjODA3&t=dE1UWGhIdXR0WnZkdGFzc0UzRC9xbEJUOHdWRUxLbVROYzFyQU4vYVZxTT0=&h=8d52b2a8b010478e8afd64054f761bba>
> Qgis-user mailing list
> <https://eu-central-1.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NWJmNDNkYTViNDcwM2ExMzMzYzBjODA3&t=ZUNtT2tIdmZxUFJBNjl6em5KanVjN3dOQ0IyelRWTGJUSkd1aW83amdGbz0=&h=8d52b2a8b010478e8afd64054f761bba>
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220221/f4ce1ad5/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220221/f4ce1ad5/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220221/f4ce1ad5/attachment.png>
