[Qgis-user] linux box accessing project-files on a windows server
Thomas Struller thomas.struller at lga-geo.de
Mon Feb 21 10:39:57 PST 2022
Hallo Rich,
Thank you for testing and investing time on my problem. That is very
nice. But i think you missunderstood my question, sorry.
I can load shp-files etc from the windows-server. The problem is, that
I want to open a project with a lot of layers (20 and more) that was
created on a windows box with relative paths.
On opening this file qgis asks me for the path for all my layers. Qgis
does not find the layers by itsself like on windows. For all my layers
(shape, geopackage-layers, rasters) i have to point to the directory or
to the geopackage on the file-server. That is very annoying. And i'm
surprised that i'm the only one having this problem.
kind regards
Thomas
Am Montag, dem 21.02.2022 um 08:49 -0700 schrieb Richard Greenwood:
> I did a quick test. I installed QGIS 3.22 on a Windows 7 computer,
> created a project. Switched to Linux Mint, used the file manager to
> navigate to the Windows computer, double clicked the project and it
> opened correctly. The path that QGIS displays in the properties/info
> panel is:
>  Path
>  /run/user/1000/gvfs/smb-
> share:server=w7,share=c$/Temp/ASSESSOR_ROADS_2018_3.shp
> I went back to the Windows computer, exported the shapefile to a
> gpkg, saved the project. Reopened it in Mint, all good. QGIS info for
> the gpkg layer:
>  Path
>  /run/user/1000/gvfs/smb-share:server=w7,share=c$/Temp/test.gpkg
> I also tested putting the gpkg in a folder below the project file and
> that opened correctly on the Linux computer.
> So I suggest that you start with a simple test project. Also, the
> project .qgz file is just a gzipped xml file. So you can unzip it,
> open the .qgs file in a text editor and search for "source=" to see
> what path info has been saved with the project.
> Rich
> On Mon, Feb 21, 2022 at 3:38 AM Thomas Struller <
> thomas.struller at lga-geo.de> wrote:
> > Hallo Nicolas,
> > thank you for your reply. All my project files are on one network
> > drive and I prefer to use geopackages. Perhaps it the problem is,
> > that I install qigs from flathub. I’m wondering about that I am the
> > only one who uses qgis on linux and want’s to access project-files
> > on a windows file server.
> > Mit freundlichen Grüßen
> > Thomas Struller
> > Diplom Geologe (Univ.), BDG, V18
> > Sachverständiger nach BBodSchG §18,
> > SG1 Historische Recherche
> > SG2 Pfad Boden – Gewässer
> > Akademischer Geoinformatiker
> > Tel:       0049 911 12076 111
> > Mobil:   0049 170 33 20 494
> > Mail:     thomas.struller at LGA-geo.de
> > LGA Institut für Umweltgeologie und Altlasten GmbH
> > Christian-Hessel-Straße 1
> > 90427 Nürnberg
> > info at LGA-geo.de
> > www.LGA-geo.de
> > Von: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> > Gesendet: Montag, 21. Februar 2022 02:13
> > An: Thomas Struller <thomas.struller at lga-geo.de>
> > Cc: qgis-user at lists.osgeo.org
> > Betreff: Re: [Qgis-user] linux box accessing project-files on a
> > windows server
> > Hi,
> > My guess is that the files you are using are, perhaps, in different
> > drives. If you save with a relative path, I think it will work if
> > you have files in a simple directory structure but if you have
> > files from multiple drives, then perhaps QGIS is forced to uses a
> > drive lettre like  c:\ and that would not go well on a Linux box.
> > Just a guess
> > Nicolas Cadieux
> > https://gitlab.com/njacadieux
> > > Le 19 févr. 2022 à 06:15, Thomas Struller <
> > > thomas.struller at lga-geo.de> a écrit :
> > >  Hallo list,
> > > sometimes I use a linux mint box with qgis 3.22.3. I have to
> > > access
> > > qgis project files over vpn on a windows-fileserver.
> > > The problem, I can't open these projects. In Qgis (linux-box) i
> > > can
> > > browse to the directory on the windows-fileserver with the qgis-
> > > project
> > > file, but qgis opens a window that shows not available layers. In
> > > fact
> > > no layer of my projet is available.  On my windows box I stored
> > > the
> > > project files with relativ project-path and in qgz format.
> > > What do I not see or what I'm doing wrong?
> > > Thomas Struller
> > > 90427 Nürnberg
> > > info at LGA-geo.de
> > > www.LGA-geo.de
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
