[Qgis-user] GRASS tools not working in QGIS 3.16.6
Gidske Leknæs Andersen Gidske.Andersen at uib.no
Thu Feb 24 00:04:19 PST 2022
I'm running a course where we use QGIS LTR (3.16.16 'Hannover'). Students or their employer have installed QGIS on their own/work computers. In a practical task where they are using the GRASS tool v.generalize some students don't get any output. There is no error message. At the end of the log in the part were outputs are loaded it is just stated that the outputs were not correctly generated (see full log below - parts are in Norwegian, but essence should be understandable regardless). We also tried another GRASS tool and again no outputs were produced, so it seems this can be a general GRASS problem.
Another student got this error message when running v.generalize:
FileNotFoundError: [WinError2] System cannot find file: 'C:\\programdata\\qgis\\processing_ENBnGW\\grassdata\grass_batch_job.cmd'
I have searched for solutions but don't find any similar cases. However, I find this that might be related:
https://gis.stackexchange.com/questions/283337/grass-cmd-file-blocked-by-group-strategy
Does anyone have any idea about what the problem could be and how to solve it?
Thanks for your help!
Kind regards,
Gidske
Log-message:
QGIS-versjon: 3.16.16-Hannover
QGIS-kodeversjon: f5778a89
Qt-versjon: 5.15.2
GDAL-versjon: 3.4.1
GEOS-versjon: 3.10.0-CAPI-1.16.0
PROJ-versjon: Rel. 8.2.1, January 1st, 2022
Kjører algoritme .
Algoritmen «v.generalize» starter .
Inndataparametre:
{ '-l' : True, '-t' : False, 'GRASS_MIN_AREA_PARAMETER' : 0.0001, 'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : None, 'GRASS_SNAP_TOLERANCE_PARAMETER' : -1, 'GRASS_VECTOR_DSCO' : '', 'GRASS_VECTOR_EXPORT_NOCAT' : False, 'GRASS_VECTOR_LCO' : '', 'alpha' : 1, 'angle_thresh' : 3, 'beta' : 1, 'betweeness_thresh' : 0, 'cats' : '', 'closeness_thresh' : 0, 'degree_thresh' : 0, 'error' : 'TEMPORARY_OUTPUT', 'input' : 'C:/GEO620_C/Lab3.1_NaturalEarth/packages/natural_earth_vector.gpkg|layername=ne_50m_admin_0_countries', 'iterations' : 1, 'look_ahead' : 7, 'method' : 0, 'output' : 'C:/GEO620_C/test.gpkg', 'reduction' : 50, 'slide' : 0.5, 'threshold' : 1, 'type' : [0,1,2], 'where' : '' }
g.proj -c wkt="C:/Users/mm249/AppData/Local/Temp/processing_eglHsD/50824fa9426e47d3bba03da90a7c5331/crs.prj"
v.in.ogr min_area=0.0001 snap=-1.0 input="C:\GEO620_C\Lab3.1_NaturalEarth\packages\natural_earth_vector.gpkg" layer="ne_50m_admin_0_countries" output="vector_620e135429c154" --overwrite -o
g.region n=83.5996 s=-89.9989 e=180.0 w=-180.0
v.generalize input=vector_620e135429c154 type="line,boundary,area" method="douglas" threshold=1 look_ahead=7 reduction=50 slide=0.5 angle_thresh=3 degree_thresh=0 closeness_thresh=0 betweeness_thresh=0 alpha=1 beta=1 iterations=1 -l output=output6f1c246e149e400685793363591c7252 error=error6f1c246e149e400685793363591c7252 --overwrite
v.out.ogr type="auto" input="output6f1c246e149e400685793363591c7252" output="C:\GEO620_C\test.gpkg" format="GPKG" --overwrite
v.out.ogr type="auto" input="error6f1c246e149e400685793363591c7252" output="C:\Users\mm249\AppData\Local\Temp\processing_eglHsD\c5ed03fd6b3e48eb8070572ae59c15a5\error.gpkg" format="GPKG" --overwrite
Starting GRASS GIS...
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files...
Executing <C:\Users\mm249\AppData\Local\Temp\processing_eglHsD\grassdata\grass_batch_job.cmd> ...
C:\Users\mm249\Documents>chcp 1252 1>NUL
C:\Users\mm249\Documents>g.proj -c wkt="C:/Users/mm249/AppData/Local/Temp/processing_eglHsD/50824fa9426e47d3bba03da90a7c5331/crs.prj"
C:\Users\mm249\Documents>v.in.ogr min_area=0.0001 snap=-1.0 input="C:\GEO620_C\Lab3.1_NaturalEarth\packages\natural_earth_vector.gpkg" layer="ne_50m_admin_0_countries" output="vector_620e135429c154" --overwrite -o
C:\Users\mm249\Documents>g.region n=83.5996 s=-89.9989 e=180.0 w=-180.0
C:\Users\mm249\Documents>v.generalize input=vector_620e135429c154 type="line,boundary,area" method="douglas" threshold=1 look_ahead=7 reduction=50 slide=0.5 angle_thresh=3 degree_thresh=0 closeness_thresh=0 betweeness_thresh=0 alpha=1 beta=1 iterations=1 -l output=output6f1c246e149e400685793363591c7252 error=error6f1c246e149e400685793363591c7252 --overwrite
C:\Users\mm249\Documents>v.out.ogr type="auto" input="output6f1c246e149e400685793363591c7252" output="C:\GEO620_C\test.gpkg" format="GPKG" --overwrite
C:\Users\mm249\Documents>v.out.ogr type="auto" input="error6f1c246e149e400685793363591c7252" output="C:\Users\mm249\AppData\Local\Temp\processing_eglHsD\c5ed03fd6b3e48eb8070572ae59c15a5\error.gpkg" format="GPKG" --overwrite
C:\Users\mm249\Documents>exit
Execution of <C:\Users\mm249\AppData\Local\Temp\processing_eglHsD\grassdata\grass_batch_job.cmd> finished.
Beregningen ble utført på 1.34 sekunder
Resultat:
{'error': 'C:\\Users\\mm249\\AppData\\Local\\Temp\\processing_eglHsD\\c5ed03fd6b3e48eb8070572ae59c15a5\\error.gpkg',
'output': 'C:\\GEO620_C\\test.gpkg'}
Last resultatlag
De følgende lagene ble ikke riktig dannet.
. C:/GEO620_C/test.gpkg
