[Qgis-user] OSGeo4W Shell with Unix-Style Terminal?
Mike Treglia mtreglia at gmail.com
Thu Jul 7 09:20:52 PDT 2022
Thanks, Jürgen, for the quick response! Much appreciated!
I think I might be missing some of the knowledge I need to implement this
for now, which is alright. For example, I'm not sure where I should start
adjusting things in that portion of the build_helpers script, and
where/when I should run that, or if I'm should modify that portion of
build_helpers (ln 107-143) and insert that into /c/OSGeo4W/bin/o4w_env.bat,
such that the OSGeo4W.bat file will call on the desired environment.
Thus, I would definitely value any more insight/guidance on this, and I can
keep working with OSGeo4W in the existing setup for now too if I need
without issue - its honestly more of a convenience item than a necessity.
Thanks again!
Mike
On Thu, Jul 7, 2022 at 10:54 AM Jürgen E. Fischer via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi Mike,
> On Thu, 07. Jul 2022 at 10:08:21 -0400, Mike Treglia via Qgis-user wrote:
> > I was hoping to use the OSGeo4W shell from a unix-style terminal - like
> git
> > bash or similar. For some things, in the past, I've added the directory
> > with binaries from the OSGeo4W install to my Windows Environment System
> > Variables for as a value in Path.
> Adapt fetchenv
> https://github.com/jef-n/OSGeo4W/blob/master/scripts/build-helpers#L107
> to your
> shell and fetchenv /c/OSGeo4W/bin/o4w_env.bat.  That way you should get all
> veriables the batch files setup into your environment.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220707/3c8e24a4/attachment.htm>
