[Qgis-user] OSGeo4W Shell with Unix-Style Terminal?
Jürgen E. Fischer jef at norbit.de
Thu Jul 7 07:54:13 PDT 2022
Hi Mike,
On Thu, 07. Jul 2022 at 10:08:21 -0400, Mike Treglia via Qgis-user wrote:
> I was hoping to use the OSGeo4W shell from a unix-style terminal - like git
> bash or similar. For some things, in the past, I've added the directory
> with binaries from the OSGeo4W install to my Windows Environment System
> Variables for as a value in Path.
Adapt fetchenv
https://github.com/jef-n/OSGeo4W/blob/master/scripts/build-helpers#L107 to your
shell and fetchenv /c/OSGeo4W/bin/o4w_env.bat.  That way you should get all
veriables the batch files setup into your environment.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220707/7b979025/attachment.sig>
