[Qgis-user] qgis user profile configuration
Juan Rafael Suárez juanrsuarez267 at gmail.com
Thu Jul 7 13:58:07 PDT 2022
Thanks Andrea, finally following your recommendations I could solved it.
The problem was that the custom profile had definitions for the "Locale
(numbers, date and currency formats) different that those defined for my
p.c. configuration. So I override them with the same my p.c. uses for a new
profile. After y close the program and open again with the new profile, the
things are working o.k.
Thanks a lot.
El jue, 7 jul 2022 a las 15:15, Juan Rafael Suárez (<
juanrsuarez267 at gmail.com>) escribió:
> I have the issue in any way, with the custom user as well with a new
> profile, and I have the same issue even if I dont override the system, in
> fact I tried to override it in order to see if I could solve the problem:
> The default system appearing is: User interface translation: American
> English
>                                                      Locale (numbers, date
> and currency formats):  There is nos any selected.
> Qgis version: 3.22.8-Bialowiesa     Qgis code revision:    8de9761df
> Qt version:  5.15.3
> Operative System: Windows 10, 64-bit Operating System, x64 based processor
> El jue, 7 jul 2022 a las 14:27, Andrea Giudiceandrea via Qgis-user (<
> qgis-user at lists.osgeo.org>) escribió:
>> *Juan Rafael Suárez*
>> *Thu Jul 7 08:03:22 PDT 2022*
>> Good morning everybody, I had some problems with some weird symbols (arabic
>> characters) in the legend when I was trying some classifications.
>> Andrea advice me to try to configure my user profile.
>> Hi Juan Rafael,
>> just to be clearer, I've suggested you to create and use a new QGIS user
>> profile [1]. Have you created and used a new QGIS user profile? Does the
>> issue occur also using a new user profile?
>> I see in the attached image that you have overridden the System Locale.
>> What is your default System Locale? What is the Operative System language?
>> Does the issue also occur using the default System Locale?
>> This might also be an issue related to the default Qt fonts. Have you
>> tried to specify a custom font?
>> Anyway it could be useful to specify the exact QGIS version you are using
>> and how did you install it and on what Operative System exactly, in order
>> to help somebody to help you.
>> Best regards.
>> Andrea
>> [1]
>> https://docs.qgis.org/3.22/en/docs/user_manual/introduction/qgis_configuration.html#working-with-user-profiles
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220707/34d99fd3/attachment.htm>
