[Qgis-user] qgis user profile configuration
Juan Rafael Suárez juanrsuarez267 at gmail.com
Thu Jul 7 13:15:46 PDT 2022
I have the issue in any way, with the custom user as well with a new
profile, and I have the same issue even if I dont override the system, in
fact I tried to override it in order to see if I could solve the problem:
The default system appearing is: User interface translation: American
English
                                                     Locale (numbers, date
and currency formats):  There is nos any selected.
Qgis version: 3.22.8-Bialowiesa     Qgis code revision:    8de9761df
Qt version:  5.15.3
Operative System: Windows 10, 64-bit Operating System, x64 based processor
El jue, 7 jul 2022 a las 14:27, Andrea Giudiceandrea via Qgis-user (<
qgis-user at lists.osgeo.org>) escribió:
> *Juan Rafael Suárez*
> *Thu Jul 7 08:03:22 PDT 2022*
> Good morning everybody, I had some problems with some weird symbols (arabic
> characters) in the legend when I was trying some classifications.
> Andrea advice me to try to configure my user profile.
> Hi Juan Rafael,
> just to be clearer, I've suggested you to create and use a new QGIS user
> profile [1]. Have you created and used a new QGIS user profile? Does the
> issue occur also using a new user profile?
> I see in the attached image that you have overridden the System Locale.
> What is your default System Locale? What is the Operative System language?
> Does the issue also occur using the default System Locale?
> This might also be an issue related to the default Qt fonts. Have you
> tried to specify a custom font?
> Anyway it could be useful to specify the exact QGIS version you are using
> and how did you install it and on what Operative System exactly, in order
> to help somebody to help you.
> Best regards.
> Andrea
> [1]
> https://docs.qgis.org/3.22/en/docs/user_manual/introduction/qgis_configuration.html#working-with-user-profiles
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220707/175da750/attachment.htm>
