[Qgis-user] Shapefile to KML conversion
krishna Ayyala ayyalakrishna at gmail.com
Sat Jul 9 19:10:25 PDT 2022
I have installed the KML tools plugin. Used the Export kmz tool. That
progressed until 99% and stopped working. Is there an alternative or
solution for this?
Regards.
On Sat, Jul 9, 2022 at 7:43 PM C Hamilton <adenaculture at gmail.com> wrote:
> Creating a KML that large is usually not a good idea, but if you still
> want to try it install the KML Tools plugin. It can usually handle larger
> data sets.
> Best wishes,
> Calvin
> > On Jul 9, 2022, at 6:19 PM, krishna Ayyala via Qgis-user <
> qgis-user at lists.osgeo.org> wrote:
> > Hello,
> > I have a shapefile of size 5GB. I have added it onto qgis map. Right
> click---->Export----> Save Feature as and I picked kml format and saved the
> file. The resulting kml has a size of 1.67GB. But when I open the kml file,
> I get the following error. No results - empty kml file.
> > Regards.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220709/6e78c471/attachment.htm>
