[Qgis-user] Shapefile to KML conversion
Gordon Wakelin-King gwakelin-king at 3doil.com.au
Sat Jul 9 19:22:28 PDT 2022
There may be better ways to do this but if it was me I'd try exporting as two files split as simply as possible, then either (1) recombining in whatever application they are destined for, or  (2) recombine them by manually editing the KML files in a big text editor like Ultraedit.
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of C Hamilton via Qgis-user
Sent: Sunday, 10 July 2022 11:43 AM
To: krishna Ayyala <ayyalakrishna at gmail.com>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Shapefile to KML conversion
Creating a KML that large is usually not a good idea, but if you still want to try it install the KML Tools plugin. It can usually handle larger data sets.
Best wishes,
Calvin
> On Jul 9, 2022, at 6:19 PM, krishna Ayyala via Qgis-user <qgis-user at lists.osgeo.org> wrote:
> Hello,
> I have a shapefile of size 5GB. I have added it onto qgis map. Right click---->Export----> Save Feature as and I picked kml format and saved the file. The resulting kml has a size of 1.67GB. But when I open the kml file, I get the following error. No results - empty kml file.
> Regards.
> Qgis-user mailing list
